I started disassembling the transmission last night. I didn't have a ton of time and didn't want to go too far without my helper so she can learn these things too. I got the stuff all removed from the case (detent balls, reverse switch and shifter mechanism), and then I cracked the case open and cleaned the sealing surfaces. The whole thing will get blasted out with a cleaner before reassembling.
