Old 05-11-2016, 03:38 PM   #21 (permalink)
Sunaj
None - '00 Chevy Malibu LS
Originally Posted by elhigh View Post
If you can, install a pulley on a spindle as an idler where the PS pulley was. It's a parasitic drag but nothing like the PS.
Alternatively, move the alternator to where the PS was. Find a belt short enough to give the tensioner a little resistance to keep everything else turning.
only problem with the spindle is it would need to bolt up to the bracket just as the pump was as well as having way of attached the spindle to it. i was thinking of gutting the pump and somehow leaving the pulley part where it can still spin freely, never done it so wouldnt no how it would work. might not be seeing this right, do you have any references?
also the alternator swap idea.... not sure if the alternator can fit in the power steering pumps location, arrrgggh
