Old 05-12-2016, 01:49 PM   #7 (permalink)
freebeard
Not bad for... fixing a latch on the washer/dryer?
The 3/4" material would be stiffer if it had a slight curvature. Make some lens shaped ribs with a tension tie on the flat (inner) side (so it will resist flattening back out).
Your straight angle cuts will become curves at the miter. You can relax the angle and get the same rear cross section.
Also—massively boat-tailed wheel spats.
