Old 05-12-2016, 11:22 PM   #2 (permalink)
MobilOne
If, by water distributor, you meant the water pump, that is not normally where the temperature of the water/coolant is measured. It is normally measured somewhere near where the coolant leaves the engine to go to the radiator. Somewhere on the engine block or head.
