Old 05-14-2016, 02:56 PM   #24 (permalink)
aerohead
front clip
Though aerodynamics are the least concern of a Wrangler buyer, moving the engine a few inches back in order to get some clearance for a more aerodynamic front clip would also lead to another benefit as it would improve stability due to the weight bias better distributed between the axles.
The whole front end can be modified by a padded bra (falsy).
Sculpt a radius'd nose out of contact cement-joined urethane foam blocks (discarded foam sofa cushions) with an electric carving knife,covered by a tailored and sewn,Naughahyde cover,attached to the nose in identical fashion as an ordinary automotive bra.
(you can actually buy a low-cost commercially produced bra and harvest all the attachment pieces from it to sew onto the new unit.
The added weight will be meaningless.
You might need testosterone replacement therapy though.
