Hi,
Im from the UK. Im loving this forum
Im going to do this mod to my car but iv read that it may be best to do it from the fused that controls the injectors to cut them off.
Am i right in thinking that i will need an Normally Open switch? So when i press it, it makes contact and allow current to flow?
Also i like how you added the toggle switch to enable/disable the function, i think i will also be adding this. May put a cool fighter yet switch for the enable/disable, so it cant be accidentally pressed.
Thanks
