Old 05-15-2016, 07:34 PM   #3 (permalink)
dfeldt91
Mazda 3 - '06 Mazda 3 iTouring
Originally Posted by Old Tele man View Post
No airbags? Obviously not planning on ever being in an accident, are you?
The seats will be replaced with lightweight seats. The original seats have airbags in them which when unplugged deactivates the entire airbag system. I can add a resistor in to eliminate the light that says there is an issue with the airbags however doing so will make it so the airbags cannot be set off seeing as it limits the voltage. That is the reason behind removing all the airbags.
