Old 05-15-2016, 09:21 PM   #9 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
Originally Posted by Natalya View Post
Accuracy and response time are kinda important.
Question 1:
If I buy a probe/tap combo thing like your picture above, will it still work with the readout device I have? Or would it in all likelihood be calibrated wrong? I could test it with a kettle of boiling water, but I think it's better to find out before I buy it.
Question 2:
Assuming any probe/tap combo like that which I got would be calibrated wrong for my readout thing, what I was trying to ask in OP was is there just the tap portion I can buy somewhere then put my probe into that empty tap? Or maybe I just get a bolt and drill a hole in it that fits then use the bolt as a tap?
If accuracy and response time are important, the sensor needs to be in the coolant.
The readout is designed for a certain type of sensor. If it is designed for a Type K thermocouple, an RTD will not work. The readout instructions will tell what type of sensor will work.
Threaded sensors usually have pipe threads. Pipe threads are cut on a taper so that the sensor will fit tight when screwed in. Pipe thread sizes can be confusing - a 1/4" NPT thread is about 1/2" diameter.
The tap thing you asked about is called a thermowell. They are expensive because they are used in difficult industrial applications. You would be better off to get the right sensor.
The Following User Says Thank You to JRMichler For This Useful Post:
Xist (05-17-2016)
