Old 05-16-2016, 02:41 PM   #2006 (permalink)
freebeard
Would you like to know more?
https://en.wikipedia.org/wiki/Hemisp...ustion_chamber
https://en.wikipedia.org/wiki/Chrysler_Hemi_engine
While USAians got V-6 and V-8s, the Oztralians got an inline six:
https://en.wikipedia.org/wiki/Chrysler_Hemi-6_Engine
The Hemi-6 is a pushrod O.H.V. (overhead valve) engine, with combustion chambers comprising about 35% of the top of the globe. This creates what is known as a low hemispherical shaped chamber. Although the Hemi-6 does not contain truly hemispherical combustion chambers, the "Hemi" moniker was used primarily for its marketing cachet based on the reputation of Chrysler's 1950s-1970s (true) Hemi V8 engines.
The Hemi-6 valves are 18 degrees (included angle) along the crankshaft axis opposed valves, with intake valves as large as 1.96". The 6 intake and 6 exhaust valves open toward each other, and into the center of the combustion chamber. In addition, both valves are slightly inclined across the crankshaft axis (similar to a conventional "wedge" chamber). The cylinder head is a non-crossflow design, meaning the 6 intake and 6 exhaust ports are on the same (left, Australian and British passenger's side) of the engine.
I like the little Hemis:
  • 1952-53 Desoto 276c.i.
  • 1953-54 Dodge 241c.i.
Cut down into a slant-four, you'd have a 2-liter engine.
