I just want to share the belly laugh I got from "the uncalibrated Scangauge" mileage report. You guys with your Scangauges are hilarious.
If you want an accurate measure of mileage, top off your tank, note your odometer reading, drive the tank down, fill up at the same pump, then divide the gallons into the mileage.
If you want more precision, make a little dipstick for the tank.
The main thing I use my UltraGauge for is realtime MPG. I figure no matter how far its off, just tellin' me I'm doing better or worse is just what I need.
Ptero
