If you are determined, you can do it. Either milling a bracket out of some aluminum and mounting existing pulley (or a light-weight aluminum one you'd have made) from PS pump to a free-spinning breaing ($), modifying a pulley by killing the innards (way cheaper, but less efficient and some work)...
Regardless, if you can find a cheap dead power steering pump somewhere to have something to modify, it might be worth it. Modifying the existing as an experiment could leave you stranded! So be cautious if you jump into your existing one.
