Old 05-18-2016, 03:54 PM   #26 (permalink)
Sunaj
None - '00 Chevy Malibu LS
essentially all i'd need is an aluminum piece with 3 bolts oriented the same way as the ps pump, and something to do be drilled in the middle of that to allow a continuous rotating pulley. is there an official name for something like the center piece i'm needing? rotating shaft or..
i will need to explain this to a fabrication shop in exact terms as many i've called seemed impatient and unwilling to help map this out
