Im planning on doing this EOC mod within this next week. Just waiting for parts to arrive.
Im planning on dirupting the Crankcase sensor signal to cut the engine as it seems to be the simplest and best way for me to achieve what i want.
I have a question regarding wiring though. Im wanting to add a toggle switch inline with the momentary closed switch, so that when the toggle switch is in the off position the momentary switch will not be able to interupt the sensor singal. Im not 100% sure how to go about doing this because if its in line with the momantary switch and the toggle switch is off, then the signal will also be interupted this way, and thats not what i want. I want to be able to just make the momentary switch active or deactive.
thanks
