Originally Posted by marky899
I have a question regarding wiring though. Im wanting to add a toggle switch inline with the momentary closed switch, so that when the toggle switch is in the off position the momentary switch will not be able to interupt the sensor singal. Im not 100% sure how to go about doing this because if its in line with the momantary switch and the toggle switch is off, then the signal will also be interupted this way, and thats not what i want. I want to be able to just make the momentary switch active or deactive.
Because you are interrupting the signal directly with the momentary switch, it will be difficult to also add a toggle switch. The only method I can think of is to add a relay.
Use a relay to interrupt your crankcase signal. The toggle switch and momentary switch in series would be used to apply power to the control (coil) side of the relay. You could do the same thing with a FET or transistor but a relay is probably simpler.
