Just lean on the battery really hard, do 2nd gear takeoffs and just WOT to draw as much from the IMA system as possible. Drain it completely, then drive conservatively to recharge. Repeat that one more time, if it doesn't code or do a negative recall, it's probably in at least OK shape.
