Old 05-20-2016, 05:16 PM   #11 (permalink)
aerohead
expect
Originally Posted by gafhj View Post
Can you clarify, 26% reduction was for such simplified body?
Less than I'd expect.
Yes,the drag reduction is for this simple wind tunnel model,which we know little about.
From what we know from public domain literature,the boat tail they tested could be improved substantially,aerodynamically.
*edge radii can be improved
*morphing into a more elliptical cross-section would honor Morelli's research
*their diffuser section is completely wrong,aerodynamically,however,probably a 'practical' concession to SAE departure clearances
With an 'active' diffuser,the angles could be maintained at the drag minimum 2.5-degrees to 4-degrees depending on 'long' or 'short'.
If 26% translated to the actual vehicle,this would yield around Cd 0.28,which is pretty good for a full-size SUV.
With 'corrections', we might expect to see 26+%.
BamZipPow (05-23-2016)
