Old 05-21-2016, 02:23 PM   #12 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
Originally Posted by aardvarcus View Post
Chopstix,
Yeah, the Suburban also needs some tire spats. I am thinking of a conveyor belt design that has been discussed on here a few times, that way it can stand up to road/offroad abuse. I want to figure out a way to fit the OEM semi-smooth hubcaps to stock 8 lug alloys so save some weight over stock 8 lug steels.
I understand about overheating GMs because of air flow, I had a 1991 k2500… one engine and multiple transmission repairs later I figure out the AC condenser is clogged up and won’t let air through the radiator. (FYI go check and/or gently clean your condenser and radiator.)
If you are looking to DIY a electric fan conversion, search on here for the one I did on my Tacoma. It wasn’t cheap, but it is reliable. Also look at ducting the air into the radiator so it can’t just flow around. I did a partial grill block on a car I used to have, but also ducted the remaining opening direct to the radiator and my temperatures decreased, mainly because the massive airflow from the huge grill opening was going around the radiator not through.
On the wheel topic, If possible, you should weigh the aluminum wheels before you commit to using them. Most are actually heavier than steel wheels.
Another idea is to copy the "knife edge" post in the mod list. I've pondered the concept of testing taped on plastic edges on the round rear corners of my van. Its suggests that it breaks the air better which could make a difference. Others can explain this better, but maybe it would help out the bricks we drive. Since a full on boat tail is not realistic when we have and use the rear doors on our vehicles. Plus it would be very easy to implement if it actually worked.
@freebeard, love the bug pic's!!! I will own a bug one day, though not for ecomodding reasons....
