Old 05-24-2016, 12:23 PM   #8 (permalink)
NeilBlanchard
I think the underside will generate some downforce, which will pull air from somewhere - in under the sides, and/or causing turbulence in the wake? Getting "replacement air" is most difficult and problematic under a moving vehicle, because the ground constricts the air flow.
