Old 05-25-2016, 03:47 PM   #22 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
A guy used gorilla tape on this forum to help attach snap on moon hub caps. I don't know if that would help you or not. Just something that I read. He claimed "its like duct tape on steroids, and the caps are now a bear to remove".
I picked up a roll of urethane lawn edging in black. Some kinds have the L top. This kind has the full rounded loop top on the lawn edging. I'm going to use it to make a small nose spoiler that stops at the same level as my cross member. This will fill the roughly 1 inch difference between my bumper cover height and the cross member. But my plan is to make a nose pan that mounts to the loop of the lawn edging going back to the cross member. Then on the sides, I'll cut additional sections of the edging and bolt/glue them on as spats. I'm copying the 40mpg Ford Ranger shown on this forum, with a couple changes that better apply to my van. Then later on I'll buy a roll of the L type lawn edging to use as side ground effects.
Lastly I emailed the guy from the university of Michigan who wrote the tech article that I briefly mentioned before. I have not yet gotten a reply. But I want to make sure about what exactly that tech article contains before I spend the money to buy it since its suppose to be about aero mods for suv's and vans.
The Following User Says Thank You to ChopStix For This Useful Post:
aerohead (05-25-2016)
