The resistors will increase power consumption to nearly the same level as before changing to LEDs.
I don't bother changing the turn signal lights because they aren't used continuously, and are only on half the time when they are engaged.
My primary reason for changing the brake lights was to have faster activation time. At freeway speeds, the faster activation time can give drivers behind another 20ft of stopping distance.
Finally, I like not having to ever replace the bulbs. I'll never get pulled over for having a bulb out.
