Old 05-27-2016, 05:33 PM   #346 (permalink)
IamIan
IamIan's Avatar
Originally Posted by jamesqf View Post
The cells in the Insight aren't exactly compatible with the HCH. The Insight has sticks of 6 cells, the HCH has 12 cells glued into a unit (like two sticks next to each other). So it'd be a little work taking them apart to interchange them.
Gen1 HCH also used the 6 cell sticks .. could be used as direct replacements for Gen1 Insight 6 cell sticks.
It was later generations of HCH that they used two sticks together as a single subpacks.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following User Says Thank You to IamIan For This Useful Post:
Ecky (05-27-2016)
