Old 05-28-2016, 01:08 PM   #2043 (permalink)
freebeard
Could you draw up you're interpretation of what I have described now mind you it must have an opening hatch that you can put a refrigerator and strap the top down...
Could you? Because your not asking for much.
Start with a piece of quadrille paper. Lay out the cross section of your cab and approximate the cross section of the Hanomag. You'll find the Hanomag's greenhouse is ~2/3rds the width of the body and much closer to the rear axle line. And continuously curved, rather than slab sided and topped.
Then move on to the open and closed position. Not even how, just what. Then it gets interesting. The solution space, not the question.
