Old 06-02-2016, 03:49 PM   #87 (permalink)
George Tyler
Originally Posted by t vago View Post
Looking again at oil pan 4's work, I have stumbled upon this old thread.....
The circuit will shave off about 1/4 HP from the alternator during normal operation, I figure. Estimated fuel consumption will go down by about 0.4 gallon per tankful, with a little over 2.2% savings. Smaller engines will see a bigger percentage.......
Are you calculating on the alternator supplying it's rate output whenever it is running? the average load will be quite low.
The Following User Says Thank You to George Tyler For This Useful Post:
t vago (06-02-2016)
