Old 06-02-2016, 06:12 PM   #88 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by George Tyler View Post
Are you calculating on the alternator supplying it's rate output whenever it is running? the average load will be quite low.
Actually, I calculated using 14 VDC and 90 A of load.
I estimated 30 A for the PCM, injectors, ignition coils, ASD relay, fuel pump relay, O2 heaters, and fuel pump. I estimated another 15 A for the TCM, relay, and transmission solenoids. I estimated another 20 A for the instrument cluster, radio, and body control computer. Finally, I estimated another 25 A to account for the blower motor, lighting, turn signals, and the electric engine cooling fan.
The engine and transmission loads will be quite steady. The body loads will be a bit more variable due to radio output, but will be more steady than the last group of loads.
