Old 06-03-2016, 04:06 AM   #24 (permalink)
debit.servus
Originally Posted by Natalya View Post
But, as others have already mentioned, there's some low-hanging fruit in the rear wheel wells, just cover those up with coroplast. Next easiest thing would be coroplast under-body panels, or maybe building a better air dam on the front.
I don't think anyone mentioned moon disks for the wheels themselves. Basically anything in here is what you want to do to the tires. It can be done with coroplast or with sheet metal, or often times actual pizza trays if you can get some on the cheap.
Moon discs? Looks great, what is the best way to install them? Like the idea of an air dam on the front and belly pans.
I've seen people use shade cloth to aero mod the undercarriage, is this a good material to use?
... If I need to go 15 miles out of my way to get something, the break-even point is around 30 cents.
So the savings has to be 30 cents to break even?
