Old 06-03-2016, 10:36 AM   #27 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by MobilOne View Post
I have a question. Take a Ford 4.6 and a 5.4. IIRC the 5.4 is a stroked 4.6. How would they compare, mpg wise with the same set-up? Then, how would they compare if the 5.4 had a taller rear end? Just thinking.
Fuel economy by swapping in a taller rear end can be roughly guessed at by the rule-of-thumb that a percentage change in gear ratio will give you about half that percentage change in fuel economy. For instance, going from 3.92 to 3.64 (which is a 7% change) should give roughly a 3.5% increase in fuel economy.
Don't know about the change in displacement, though. Couldn't even venture a guess on that one.
