Old 06-03-2016, 12:21 PM   #8 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Mustang mod wise if you can think it, you can do it. I can put in a 5 speed, 6 speed, gear ratios from 2.73-4.56 FD, underdrive pullies, electric water pumps, I can even swap the hydraulic steering on any 05-14 mustang to EPAS from a junkyard 11-14 car but cost is around 1000$ and weight gain is like 40 pounds. Not really worth it since i'm into autocrossing and will eventually compete in a 300hp 4.6 vs 500+ 5.0's.
The only thing kind of ironic though is that if you have a v6, compatibility with half the mods I listed is kind of nulled out. lol
In it's current state it has the cats deleted, louder mufflers, tune, intake, charge motion control valves deleted (cmcv deletes: mistake, cold starts use more gas, less low end, no noticeable change in top end). Making 350bhp. Then full suspension: custom spec coilovers by me (Ground control, bilstein), adjustable: swaybars, endlinks, watts link) and 285/35/19's. And weight reduction here and there to take the car from 3600 to 3480. But i'd rather not "race turd" a $20,000 automatic muscle car and instead start with a 05-06 $6000 manual car, starting at 3450 pounds with the lighter pre gt500 frame.
I want to compete in a stock modified class with the car so my mods will have to be legal so: I will swap the trans from the tr-3650 with 5th from 0.68 to 0.62, then weight reduction from 3450 to 3200 base weight for the class. Build a small trailer to carry tools for the track and 315/30/18 wheel setup.
I wonder how he found his values for Cd and ft2 for the mustang. I'll have to go to his thread and read it after work!
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
