Old 06-05-2016, 12:39 AM   #6 (permalink)
freebeard
[talking to myself because I'm impatient]
From that thread:
I don't think it's worth the effort to finish.With a weak slant six and all the mods I'd done she peaked at 21.5 mpg @ 65 mph,which is 3.5 mpg worse than the T-100 'naked'.
A long block is $1,400 and even with a fresh engine I'm not confident that she'd do much better than low 20s.
A spare T-100 bed for experimentation is $800 minimum.That's not going to happen.
If I didn't have to drive the truck I could do a wood-based bed/cover,but the Insight's been...
That's a shame. I like the slant six; I had one in my Cortez. If that Chrysler block is worn, that just means bigger bearings and more displacement, right?
I just came across this:
Just A Car Guy : Deus Ex Machina - 66 Plymouth Barracuda with 480hp 273 on a 4 speed.
Massive air scoops in the lower front quarters and a hot 3" pipe for a rear wheel spat on the driver's side. Does the Barracuda backlight fit the Template?
Apropros of the http://ecomodder.com/forum/showthrea...tml#post514606 thread; don't count the slant six out until you've tried a four-barrel carburetor.
$800 minimum...
PlyMetal™ Swing Door - PLYWOOD CORE WITH INTERIOR AND EXTERIOR ALUMINUM LAMINATES
Standard Sizes
49" x 110.5"
49" x 121"
Nominal
Thickness
Plywood
.500"
.750"
1.000"
1.250"
I can get this stuff [almost] right across the street for something like $100 for 4x8ft (if I had $100 ), maybe only skin on one side. So say $200 for 1 1/4" stuff. You'd cut your taper on the back half and add the scraps back on with cabinetmaker's biscuits.
Cab swap! There's got to be an old 1938 Dodge pickup cab in Texas.
aerohead (06-06-2016)
