Old 06-05-2016, 12:15 PM   #415 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Here is a article about the Mahle system that F1 teams are now using to improve efficiency and performance.
Turbulent Jet ignition pushes engine combustion efficiency - F1technical.net
The jet ignition system is a new combustion technology, patented as US20120103302 on 1 Nov 2011 that replaces the standard spark plug in SI engines with a jet ignition chamber assembly. It facilitates the implementation of ultra lean-burn operation in gasoline engines, improving their efficiency and reducing the formation of pollutants such as nitrogen oxide and particulates.
One of the main benefits of the system is that, depending on the specific design of the cylinder heads, the jet igniter can be a drop in replacement for the traditional spark plug.
The jet igniter itself includes a small ignition chamber with a direct injector (DI) that provides a small amount of auxiliary fuel (<5% of the total system fuel) and a spark plug to ignite that charge. The ignition chamber is connected to the main chamber by a number of orifices which allow jets of partially combusted products to ignite the main charge. The smaller orifice size causes turbulence in the hot gas jets which then penetrate deeper into the main combustion chamber and cause an evenly distributed ignition effect. The main chamber is fuelled through a conventional port or direct-injection injector.
With 4-8 ignition jets, depending on the application, the main charge is extensively ignited and a faster burn-through and pressure build-up is generated. Furthermore, this process allows increased compression ratios (a 4 point increase in some applications) combined with lower combustion temperatures and reduced throttling / pumping losses to achieve peak indicated thermal efficiencies up to 45% - not to be confused with the reported > 48% thermal efficiency that Mercedes is achieving for its entire F1 power unit.
The details of how Mahle has adapted the TJI system for Ferrari or obviously still held anxiously secret, but results from the various testing beds have shown promising measurements. Mahle have for instance tested various prototypes with on a visual test bed, as well as a single-cylinder engine, and found fuel efficiency gains of more than 17% over spark ignition. Apart from this increased efficiency, the potentially reduced cooling needs will be equally interesting for F1 designers, as that could allow tigher cooling packages and improved aerodynamics.
Mahle says the new design results in much quicker ignition that with standard spark ignition, "enabling the engine to operate at optimum spark timing as the knock limit is extended significantly. In car engines, high fuel savings are achieved by the higher, almost diesel-like efficiency. Engine tests show specific consumption below 200g / kWh and significant related reductions in CO2 emissions".
Pressure Gradient Force
The Positive Side of the Number Line
The Following 5 Users Say Thank You to pgfpro For This Useful Post:
LeanMeanDSM (06-06-2016), Logic (04-01-2025), mpgmike (04-17-2022), RustyLugNut (06-08-2016), Xist (06-05-2016)
