Old 06-05-2016, 06:57 PM   #15 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by California98Civic View Post
Keep a fuel log here at the site, so you can chart your numbers. Using this technique your averages will start to climb right away. Is you scan gauge calibrated?
I don't have a GPS but I used a Tremec gear calc and heres what's odd:
Speedo and RPM read ~74-75mph and ~3150ish rpm which is clearly wrong as im traveling 70mph.
From tremec's website the car should spin 2960rpm at 70 and sure enough with no offset, the scan gauge read 70mph @ 2960rpm. So goofy gauges, but the obd2 signal to the scan gauge is 100% correct.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
