Old 06-05-2016, 07:06 PM   #17 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Looking like I'll end up with this:
3.25 Final Drive trans w/ Michelin Defender 185/70/14's.
Should drop my hwy rpm from 2960 to 2219 at 70mph. Is that considered a little under geared or just fine? Drive is for the most part literally 100% flat.
I guess if I run the numbers lets see what 4th would end up at versus the original setup. . .
.909 (LX Trans) vs .853 (CX Trans)
So 70mph on the CX trans w/ new wheels would be 2696rpm.
Now that I ran the numbers that setup is looking really good.
What number's are y'all seeing on the interstate at 70mph with the AC on *1*?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
