Originally Posted by steensn
I have no problem doing a soft bump in second aroun 15 mph. I don't know if it is just my car, but I always use second gear at around 15 mph with the double clutch technique.
Try 4rth or 5th gear and see if it works, I think it would be easier on the engine. I used to bump start in the gear that I would normally be driving in at the speed in question, but have found that moving up a gear or two to bump start works better.
