Old 06-08-2016, 03:43 AM   #13 (permalink)
oil pan 4
Because they can be expensive. You cant get them at a local parts store. They need electrical power. They need to be wired into electrical power. Its hard to tell when they have stopped working. They may pump too little coolant. They might pump too much coolant. Unless you can get direct bolt on you have to fabricate stuff. You will have to rearrange your accessory drive, which involves fabricating brackets most of the time. Its an additional load on the limited power the electrical system can provide. The weigh more than the belt driven pump.
And maybe more reasons that I cant think of right now.
One of the reasons I do like the electric coolant pump is that I can use it to circulate coolant through my 5500 watt coolant heater.
Xist (06-08-2016)
