Old 06-09-2016, 11:04 AM   #33 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
The most bang for the buck in a suburban is a diesel motor.
Both the 4.3, 5.7 and 6.2 (c-code) motor when put in with a manual transmission will give you the largest increase bone stock 2wd.
Converting it to a true FWD with a manual transaxle adds another 10-20%
So your starting point should be about 30mpg once the original platform is optimized mechanically.
If you don't mind super slow driving drop in a Kubota for up to 50mpg at low speeds.
Then underbelly, fender skirts and the rest after you get the lowest hanging fruit.
The Following User Says Thank You to rmay635703 For This Useful Post:
aardvarcus (06-16-2016)
