Old 06-09-2016, 01:34 PM   #12 (permalink)
HybridGates
Originally Posted by CapriRacer View Post
Hi. Barry of Barry's Tire Tech here!
Large amounts of over-inflation pressure tends to cause rough ride, wet traction issues, center wear, groove wander, and increased puncture rates, but improved overall wear rate, fuel economy, and steering crispness. Dry traction and vibration (balance) seem unaffected. The jury is still out on whether overall durability (that is, structural failures) are affected or not as the trend seems to be there, but there aren't a lot of data points. Please note that all of the above is based on anecdotal data and self-reports over the internet. It's reliability is suspect, but it is the only data available.
I used to run a set of tires at 51 cold, and never once suffered from center wear or bad wet handling. As for trends, the only ones I have seen it for are tires inflated below some 25 psi cold, as there was a famous incident back in the 90s for firestone tires I believe. So 25 cold I assume would be like 32 hot?
Either way, its obvious some tires perform better at higher pressures then others, and hence better fuel economy, what I want to know is which LRR get the best fuel economy while not sacrificing anything else with high pressure.
