Old 06-10-2016, 11:14 AM   #28 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by ChazInMT View Post
Also, direct power from a belt for an accessory is always more efficient, at a given load, than converting engine power to electricity than using the electricity to run the load.
As you know, the trouble is that the water pump load will change only as a direct result of engine speed. At that point, it becomes a debate whether to continue to mechanically drive the pump at a 1% loss due to the drivebelt, or electrically drive the pump at anywhere between a 30% to 45% loss from conversion from mechanical energy to electricity, but gain a net 1% to 3% increase in fuel efficiency at the same time.
This Hot Rod magazine article has a rather interesting take on electric water pumps.
Baseline Testing - Do Water Pumps Suck Power? - Hot Rod Magazine
I gathered, from reading the article, that it might be best just to get an underdrive pulley.
The Following User Says Thank You to t vago For This Useful Post:
ChazInMT (06-10-2016)
