Old 06-11-2016, 12:34 AM   #33 (permalink)
serialk11r
Originally Posted by t vago View Post
As you know, the trouble is that the water pump load will change only as a direct result of engine speed. At that point, it becomes a debate whether to continue to mechanically drive the pump at a 1% loss due to the drivebelt, or electrically drive the pump at anywhere between a 30% to 45% loss from conversion from mechanical energy to electricity, but gain a net 1% to 3% increase in fuel efficiency at the same time.
This Hot Rod magazine article has a rather interesting take on electric water pumps.
Baseline Testing - Do Water Pumps Suck Power? - Hot Rod Magazine
I gathered, from reading the article, that it might be best just to get an underdrive pulley.
Worth remembering that at high rpm, the eddy current losses of the alternator are very high and the efficiency is usually under 50%, so that cuts the peak power saving down a bit.
At idle the mechanical pump is almost certainly more efficient than the electrical pump. However 50% greater pump speed = 1.5^3 = 3.375x as much power, so any time the engine is more than just barely above idle you're saving power with the electric pump.
