Originally Posted by The donkey CRX
Hi Mark, My research says that it makes very little difference in drag, as long as the air is prevented from entering the engine compartment. Some air fills the small recess in front and all other air flows over and around the car. You may have noticed that most OEM grill blocks are also recessed this way.
Hi
yeah i have noticed on alot of new cars they make it look like it still has a grill when infact its blocked off just a couple inches behind.
Definalty something to consider as on my car there are 4 open areas and 3 of them are quiet deap so alot of air would go into the space but be pushed back out due to the block.
