Originally Posted by t vago
It sounds like the MPGuino is being fed a VSS signal that is too fast for it to handle.
Can you tell me what vehicle speed that above o'scope output represents?
Thanks for reply
Around 50-60km/h
/// 31-37mp/h I believe i did at that momment.
Yeah, otherwise why would it seem fine and then drop?.
But then.. wouldn't my car be strange different than others?, if it makes a signal so fast that the MPGuino can't follow?.
I have been thinking that i could try and tap into the signal before the signal generator/amplifier, if that would make a difference.
Any suggestions for oscilloscope settings and what i should then be seeing are welcome too.
