Thread: VSS problem
Old 06-13-2016, 11:28 PM   #8 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by mirkwood View Post
Hehe yeah okay, really really high.
Yeah, I just noticed this guy had similar problem http://ecomodder.com/forum/showthrea...mit-29787.html
and he was to do a divider aswell, but no conclusion.
Hmm... is this something that can be bought somewhere pre-built?, I tried to do a search, but either i am not using the right words, or then it is rare.
If i am to solder myself then i need a really detailed plan. Soldering no problem, but schematics not my strongest side.
You could get yourself a 4013 dual D flip-flop CMOS chip. It's a fairly basic piece of 1970s technology that should cost around $0.50 per chip. It will accept a car battery or alternator voltage with no problem.
Here's a datasheet for one -> https://www.fairchildsemi.com/datash...D/CD4013BC.pdf
Get a 14-pin DIP chip, a 14-pin DIP socket for the chip, a 0.1 uf capacitor (preferably not electrolytic), and solder jumper wires as described in the below pin assignments:
10 <-> 8 <-> 7 <-> 6 <-> 4
3 -> 2.2 kohm resistor -> 14
3 -> input Alfa VSS signal
1 -> 11
14 -> V+ (same source wire that powers the MPGuino, for instance)
7 -> ground
14 -> 0.1 uf capacitor -> 7
1 -> 11
13 -> VSS output to MPGuino
2 -> 5
12 -> 9
In another thread on a Alfa romeo site i found this, but it is an more expensive option.
Universal Speedometer Signal Interface
Where do i see the code version?, on the unit itself?.
Thanks again .
No problem.
The MPGuino version can be found on the screen, for approximately 2 seconds after it is first powered up.
