Originally Posted by aerostealth
9100 lbs is the empty weight. The hitch weight is 1500 lbs. It tows this fine. The truck is rated up to 11300 lbs.
Is it a regular cab? Does it have the Max Trailer Towing Package? What axle gears does it have?
...The frontal area is basically 97 sq ft...
Your truck has a Frontal Area Limitation of 60 sq. ft. if equipped with the Max Trailer Towing Package or Heavy Duty Payload Package and only 36 sq. ft. without them.
