Old 06-18-2016, 05:29 PM   #3 (permalink)
freebeard
MOON Disc Screw-on Type
MOON WHEEL DISCS can be made up to 46" in diameter. Don't see your size listed? Contact us for custom applications.
You have a semi-circular wheel arch, probably 28-29" or so in diameter. A single 32" custom spun disk might cost ($200?) but you could cut it in half and align the free edge with the up-sweep in the body lines. Dzus fasteners in the overlap.
Or use 2/3rds of two and hammerform the bottom edge as necessary.
aeroheard -- It is interesting that they found the rear skirts more effective than the fronts.
aerohead (06-18-2016)
