Did the water pump come with a plastic plug in the suction side?
Was a rag or paper towel used to keep the hoses from dripping when they were disconnected?
If so, it's possible that the mechanic didn't remove the plastic plug and or rag.
It's also possible that the radiator is full of gunk on the inside, not allowing it to
circulate.
If so, replace radiator...
