Thread: Rotten Passat
Old 06-20-2016, 09:37 PM   #53 (permalink)
dfeldt91
Mazda 3 - '06 Mazda 3 iTouring
Got some more aero work done today. Deleted the rear badge and antenna completely. I think the antenna delete will help a little bit as I believe it was what created the low pressure spot at the window which is really evident from the lack of rain in the center foot and a half of the window directly in line with the antenna... I'll be deleting the rear door handles (They do nothing as I removed the wire to the latch so it won't open from the outside). After I remove the handles I will be filling in the space with metal and bondo to make it aero. Might do the front doors as well if I can get a door popper kit.
Anyhow, here are the pics. Not quite done with smoothing it out and still need to paint it.
Got the front door panels removed today. That was probably about 15 pounds or so. Did a lot of wire removal the past couple days. Probably removed close to 5 pounds of wire.
The front speakers are riveted into the inner metal door panel so I'll have to drill those out for an additional 4 or 5 pounds of reduction. Slowly inching closer to 2500 pounds.
