I dont know why but the speedometer started working, its not calibrated but it worked. When I'm sitting still the m/g value is 0 but when am moving it gets dashes. Gal/hour always stays at 0. Then instructions on the jaycar module say to put it in the 12v wire not the switched one. I put it in like that. I re-read The page i linked before and I might need to change some of the settings. Its late and storming so I'll probably try tomorrow. I don't have an oscilloscope or a multimeter with a frequency function. Not sure how else to test the sources. I do have the factory service manual and am Confident I tapped into the correct wires.
