Old 06-23-2016, 12:55 PM   #35 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
The instrument cluster is where it is so you can see things with your peripheral vision. You can see numbers without turning your head away from the road and if you do, you can still see outside the car even if you're not "glued to it." Below the radio is a bad idea.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
mcrews (06-23-2016)
