Old 06-25-2016, 05:01 PM   #61 (permalink)
aerohead
spot welder
Youtube can show you how to make a spot welder out of an old microwave oven. With a 2-3' throat you could spot weld the whole thing. It would go faster than all that drilling and riveting (once the spot welder is made).*
Absent a female mold, the composite would require a lot more finish work than aluminum. Will it all be painted white?
_______
I've got 3 toddler bike wheels, and I'm thinking about something like all-thread or a threaded rod for the front axle. Maybe frame it with welding rod and fill with luan paneling triangles finished with aluminum tape.
You can see in the pic at Permallnk #59 there are removable straight sections before the rounded tail. Do you think I should Vee them together and drop the rounded section? A cut and two holes and I can make them any length for a fineness ratio between 3.14 and 3.72. Isn't 3.79 optimal?
*Maybe you should ignore that, will you be riveting aluminum to steel and/or wood?
*I'll be fastening blind,with access only to the outside,over partial aluminum bulkhead stations attached to what's already on the truck.Working in small facets,maybe 12" at a time,shingling the panels,from the back ,to the front of the bedcover.I did the side fairings of the bedcover this way and it worked out okay.
*Yep,white's the color.
*I'll attach wood to a chrome moly tube birdcage which is attached to the swing-mount.Aluminum attachment sections will be attached to the wood.
*I'll aluminum skin the easy parts.
*and do sculpted foam for the more exotic compound stuff.
*I've got some West System's Epoxy for the composite stuff which will help with pot life issues.(polyester would go off before I ever got it mixed)
Let me go back to permalink# 59 to catch up on that image.
