Old 06-27-2016, 02:22 PM   #23 (permalink)
RustyLugNut
There is some basis for the hype.
Originally Posted by spacemanspif View Post
Thanks Chaz, that the guy! Case closed, nothing but hot air apparently.
It is just buried deep within the drivel.
Hydrogen seeding to form reactive radicals before the onset of ignition is a basic fact of combustion science. Research continues in this.
Electrolysis produces a measured amount of ozone in the oxygen stream. Research has shown that 40ppm (parts per million) can measurably accelerate the combustion reaction. Common mineral "impurities" found in common tap water can bias electrolysis to produce more ozone.
Every HHO aficionado I have contacted knows nothing of the above. Most of the detractors fall into the same lack of knowledge. In more learned circles a "wait and see" or " more work needs to be done" conclusion usually follows a heated discussion. And that is my conclusion on this subject.
