Old 06-28-2016, 01:31 PM   #18 (permalink)
jamesqf
Would the cloths freeze after enough water boiled away? Somehow I think drying by vacuum would still require heat input.
In my experience, clothes hung on a line in cold weather (think northeast US, with high temp maybe 10F) will freeze dry if it's sunny and there's a good breeze.
With a vacuum dryer, I don't think the problem would be freezing so much as it would be maintaining a vacuum. That is, as you pump the chamber to a vacuum, some water evaporates from the clothes and raises the pressure up to an equilibrim point, so you have to keep pumping...
The Following User Says Thank You to jamesqf For This Useful Post:
herbivor (06-29-2016)
