Old 06-29-2016, 01:33 PM   #18 (permalink)
jamesqf
Originally Posted by niky View Post
After that, it's all about knowing how much grip they have and adjusting the controller accordingly.
Sure, the question is what the heck are they using that has sufficient grip?
And the ice thing, that can be dealt with via an inertial/GPS traction control system. It still won't accelerate quickly, but you can fine-tune wheel acceleration rates so that you're not needlessly spinning them up.
Yes, to a degree, but even if it's done perfectly, the acceleration will be slow (if it happens at all), simply because there isn't enough grip between tire & ice.
